Should Extent buttons on the Command Bar be sticky?
A few of releases back they made the Command Bar extent buttons remember their state
between uses.
I sometimes wish it was back the way it was. Or maybe an option to turn it off?
Every extrude or cut is a new situation and it seems unlikely that I would do more than one the same way.
The Non-symmetric Extent is the one that throws me the most.
Anyone have an opinion on this?
LMGi
www.TLMGi.com
