Show/Hide assembly relationship
solid edge don't show the assembly relationships (axial, planar, etc...) in the pathfinder (under . I have also tried to restart SolidEdge and the pc. Probably an option (in settings) has been changed but I do not know where to restore it. Can anyone help me? Thank you in advance
Re: Show/Hide assembly relationship
Hi!
You should try in "Solid Edge Options" - Assembly - Other options - Hide Relationships pathfinder (or something like these, I have the spanish version).
I hope it may be usefull.
I tried but not fix it, thanks
Could the pathfinder be expanded too far down?
(view in My Videos)
Sorry to all. I just had to get up the lower pane with the handle.
I'm a donk.
Good. And no you're not a donk. Um, what's a donk?
I think Donk is KIWI/Aussie for Dork
