Show/Hide parts in Simulation environment
Hello, I am trying to figure out how to Show/Hide parts in an assembly after performing an FEA simulation. I need to see the stresses at the interface of parts, but am unable to hide parts blocking the view.
Any advice?
Cheers!
"The society which scorns excellence in plumbing because plumbing is a humble activity, and tolerates shoddiness in philosophy because philosophy is an exalted activity, will have neither good plumbing nor good philosophy. Neither its pipes nor its theories will hold water." -- John W. Gardner
Re: Show/Hide parts in Simulation environment
I don't know of any way to hide individual parts in the Simuation environment unfortunately. When I need to view stress levels in hidden components however I either make the parts translucent or use clipping planes to remove some part geometry.
I hope that's of some use to you............
Frank
Edinburgh University
You can do this in "results" environment, If you toggle off meshes in "Simulation" tree.
FrankMill's idea is great too.
Here is a video about this:
Unfortunately, you can not create a Display configuration from these states... This can be an ER... Smiley Wink
BR,
Imics
