Show Projected curve on a part in a Drawing View
I'm fairly new to Solid Edge and im testing it out.
I've got a part where I've projected a 3d curve onto a side of a part. Is it possible to make visible this projected curve in a drawing view? There doesn't seem to be a setting to show this projected curve on the surface of the part in a drawing view.
Thank you in advance!
Betreff: Show Projected curve on a part in a Drawing View
Hi @Chris13
just see sequence in picture
List All, Seelct Curve and tunr on Show
Thank you Wolfgang!
