Show tolerances in Leader?
Is it possible to add tolerances to meassurements within a Leader?
Or do you guys have another suggestion, how to display the marked below in a more professional manner?
Kenneth
Re: Show tolerances in Leader?
I suggest using Callout command with format codes to this.
" To be %DI55 M7 after welding %{/ST+0^-0,03} "
Here is a short video about steps:
BR,
Imics
