Showing Long Lines
N/A
I can't remember what it's called but it's used to show long lines by eliminating some of the length via squiggly lines. See attached image. It shows much better what I'm trying to describe. I can't seem to locate this function in ST6. Any help would be greatly appreciated.
Ed
Re: Showing Long Lines
It's called "Add Break Lines" and it available in the shortcut menu when you RMB on a drawing view.
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
N/A
Break lines, that's it. Thank you very much.
