Showing blending of a weld
Using ST6-MP2;
I would like to show a weld bridging two surfaces. The Orange gap would be filled with weld by blending the orange surface over to and overlapping the green surface.
Note:
I am not trying to welding inside of a PSM file. I am only using this so i can color the surfaces. all my work in being preformed in the ASM file.
I can not insert a loft as a weld, which would give me the effect i am looking for, because that option does not exsist. I can not see any clean way of doing this multi extrusions maybe?
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Hi,   I don't understand crystal clear your issue, but I...
I don't understand crystal clear your issue, but I think this will help:
BR,
Imics
Imics
Re: Hi,   I don't understand crystal clear your issue, but I...
Thanks Imics I was not seeing it, but you are correct that is what I was looking for.
Nathan M. Gardner
I glad to hear this! Smiley Wink
BR,
Imics
