Simplified Assembly and configuration Issue
Hi Edgers,
I spotted some strange SE behaviour.
As you can see on attached Video, simplified assembly disappearing from the model when it shouldn't.
Having problems with Drawings using this configuration.
I do knot know what causes
(view in My Videos)
the issue.
Below I recorded a video related to drawing:
(view in My Videos)
Arek
Re: Simplified Assembly and configuration Issue
Hi
Small UPDATE:
After opening the file on the different machine, re-saved it - the problem temporarily is gone.
Shall see what the future bring.
Arek
