Simulation Workflow Overview
The simulation overflow overview on the step that says: Choose the Simulation tab- Study group- New Study command works fine
set the Study type to Linear Static, set the Tetrahedral works fine.
Select the frame go to turns yellow works fine, next step, go to the Select Occurence command click on it will not turn green, go to the frame that turns green. Also notice the windows cursor
follows the drawing will not go back to the cursor with the the SolidEdge cursor. I went back to the beginning same results
Greg
