Sketch in Assembly
1)how to give dimension reference to assembly part in assembly sketch
here i attached photo in which i want to make 4 hole on plate
now i try to give dimension of rectangle reference to the line of part but
I cant
please help me
2)when i select smart dimension ,
cursor is converted into +  like center mark
is it any way I can make it like reqular cursor
Re: Sketch in Assembly
Try checking ON Peers in the Tools tab - Edge Locate group on the ribbon, as shown:
