Sketch on Mirror Plane Bug?
I'm trying to sketch on the plane of a feature that has been mirrored. Problem is, when I change the angle of the base feature, the sketch on the mirrored plane feature becomes sick. Am I doing something wrong? See attached part file and video.
(view in My Videos)
David McMahon
Solid Edge ST10, MP3
HP Z2 Mini, Windows 10
Betreff: Sketch on Mirror Plane Bug?
Honored Contributor
Honored Contributor
Hi @David_McMahon
I can see the same behaviour here with Your part.
But, what I can not clearly understand is, what Your intends will be.
What will planes 31, 32 and 16 be used for?
How are the sketches positiioned on their planes?
They are not fully constrained, but somewhere in "plane".
Maybe a different approach will let YOu model Your part easier and more stable as this use of reference planes.
Can You give us more infos about the final goal You would like to achieve so that I can think further.
Wolfgang
Hawcad,
Thanks for confirming the issue. The video I posted was a simple example I put together to demonstrate the problem. I thought I might be doing something wrong. I'm really trying to create some sktech geometry to control a plane location. I'm sure I can figure out a workaround, but the fact that the sketch geometry does not stay constrained to the mirrored plane it was sketched in really complicates thngs.
David McMahon
Honored Contributor
Honored Contributor
Hi @David_McMahon
can You test wether a coordinate system instead of the planes will be changed associativeley?
There were situations in past where CS performed better and more stable than planes.
Wolfgang
Hawcad,
Thanks for the idea. I tried that but had the same problem. See attached video.
(view in My Videos)
David McMahon
Hi @David_McMahon
I have checked this issue, modelling a new part.
And I do not have a problem with the planes.
Please see a video attached.
(view in My Videos)
Production: SE ST10 MP3
Honored Contributor
Honored Contributor
Hi @arekkul
Yes You don't have a problem, but You also don't have a mirror feature in Your pathfinder.
The problem IMHO occurs with mirrored features and the use of such mirrored faces.
Wolfgang
Hi @hawcad
yes Wolfgang,
I missed it.
I confirm - it is a problem.
regards,
Arek
Thanks everyone for your feedback. I have narrowed the problem down to the boolean > subtract feature. I remodeled it as a mirrored cut and that worked fine. Still seems to be a bug with mirrored booleans. I have logged it with GTAC.
David McMahon
