Sketches appearing sick from the outside
I'm in an assembly that my assistant did. He's off today. But I go into this assembly to change some dimensions and there are 5 sketches showing at the assembly level, and they are all colored bright orange, which looks to me like they are sick. But when I go into the sketches everything is fine, nothing is sick. All 5 sketches look this way and they aren't linked to anything. I've tried turning off relationship colors, tried changing what colors are what in relationship colors but no matter what I do these sketches all appear bright orange from the outside. I figured at the very least turning off relationship colors would show a change in color. I even tried changing the color for overdefined to magenta just to see if that changed the color, but it did not.
(view in My Videos)
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Re: Sketches appearing sick from the outside
It's possible that he may have colored the lines orange in the sketch and turned on "Multi-colored Sketch Display".  Right click on the sketch in pathfinder and see if that is the case... If so set it to "Single Color Sketch Display".
http://Grundey.blogspot.com
@KennyGNope, I thought of that too, not the culprit.
Solid Edge 2019
What happens if you create a new completely stand-alone sketch?  Is that baby**bleep** brown also?
@chrisstandringYes, if I create a new sketch inside that assembly, once I'm outside of it it shows up as sick orange.
Solid Edge 2019
