Sketches color problem
Goodmorning everybody.
Today my problem where i think to find a solution here is that.  In assembly mode when i create a sketch this is with black lines color, and when i come back also. When i do the same step in SheetMetal or Par ambients the color is white and i can't find where i can change this settings. I don't wont select  polycromatich like on video but i would like the color to be black automatic. I hope I was clear Smiley Very Happy
(view in My Videos)
4 REPLIES 4
Betreff: Sketches color problem
Hi @And_M_One
what happens if You use a different template? (default template from SE)
I think this is a matter of a setting but can not say it out of seeing the video.
Wolfgang
I try the standard template and the sketch magically is black and visible both when it is active and when it is deactivated. Now my problem is to understand how and where I can go to change those colors because I can not change the template and use the standard because I have many variables set and exposed.
Open the template, then go to Options. Then in Colors you will find the colors.
I know where's this window but any setting in this screen is for my problem..i have set all black one times :-) and anythings is changed.. ^_^
