Skipped Download
Somehow I skipped the download step in the process and went straight to the bulletin board. Now I can't get back to the download page. Any suggestions?
Re: Skipped Download
You can go back and simply register again. there is no problem with registering multiple times.
Once you enter your information, click on the Submit button at the bottom of the page.
You will be taken to the download site. Click on your language of choice to start the download.
I suggest you Save the download locally to your machine. This way you can run the download at a later time if needed.
It will prompt to run after the Save is finished.
Rick B.
