Sloped spring
would you tell me please if its possible in SE ?
Using only equations and variables ? Or maybe different method ?
regards,
Arek
Production: SE ST10 MP8
Re: Sloped spring
Hi Arek:
Does any of the methods mentioned in this article or part 2 help to create the spring you want.
Sorry about leading to a lengthy article but hopefully someone also replies with a direct method for your question.
~Tushar
Re: Sloped spring
Hi @Tushar,
unfortunatelly it is impossible to create sloped spring using your method. ( or I couldn't find the solution )
Arek
Re: Sloped spring
any chance to get Equation Driven Curve as a new functionality to the SE ?
Arek
Re: Sloped spring
Honored Contributor
Honored Contributor
Even if you could model it, how would you make it? They are not available for purchase are they?
Re: Sloped spring
Hi @12GAGE
You have right, but this functionality is present in every other CAD software, why not to ask ?
Arek
Re: Sloped spring
Honored Contributor
Honored Contributor
I have 30 other things I need in the software first, that effects my every day work. That does not.
I only ask for things that I need daily. And I ask for a lot. See me thread called "The big ER"
Re: Sloped spring
Ive never seen a sloped spring or even know why you would need one? I know Solid Edge or Solid Works doesn't really have a way to do this
Owner: Scott Lester Drafting & Design
Designer: Rotork Instuments
Re: Sloped spring
Hi Scott,
Thank you for your response,
SW has this functionality as well as Inventor, Siemens NX or Catia.
Arek
Re: Sloped spring
to see this done in Solid Works
