Smart Dimension broken in sheet metal?
Builder
Builder
http://screencast-o-matic.com/watch/cIjIXtVgIs
For some reason I cannot place a smart dimension between two parallel flanges.
I should note that before this started happening, I used the steering wheel to give the flanges an angle up, such that they could taper to a smaller flange, but the faces still remain parallel.
Luke
Hi Luke   The Lock in plane option of the smart dimension...
Hi Luke
The Lock in plane option of the smart dimension is active. That's why you have the chocolate-like rectangle. To disable it, press F3 while inside the tool.
(view in My Videos)
Lauren J.
