Smart Dimension
Hello every one,
I try to measure a radius from the old file of solid edge from the old colleague. I could not find the way, how Can I measure ?
I could not find any mesurement tools.
I will be thankful for your answer about my question.
Best regards
11 REPLIES 11
Re: Smart Dimension
Hello @anaina
On the Inspect tab of the ribbon is Smart Measure, if you are in Draft
and additionally, Inquire Element in the Part and Assembly environments.
Tushar
www.SurfAndCode.IN
Re: Smart Dimension
I'm not sure what you're asking. If it's just how to measure a part, there are numerous measurement tools on the Inspect tab in the interface. Any version of SE will open an older file.
Alex
Re: Smart Dimension
@anaina   a screenshot would be very helpful as there are many ways to measure or inquire about dimension from SE.
Also, need to know if we are talking 2D or 3D...
Matt Johnson
Solid Edge Certified Professional
Solid Edge 2019 (SEEC) - Production
NX12 (Tc Integration)
Teamcenter 10.1.7
Re: Smart Dimension
Dear Tushar,
thank you for your answer. My problem is that I cant find this tabs in solid edge.
see attach please.
Best regards
Re: Smart Dimension
Youre absolutely right. You will find from  now the Screenshot in  attachment.
Best Regards
Re: Smart Dimension
Right click on any button on the ribbon bar and from the context menu that appears, select Themes which is the last one and then select the 'Maximum assistance' theme.
This should restore the Inspect tab on the ribbon.
Re: Smart Dimension
well done.
Thank you
Re: Smart Dimension
@anaina
looks like you have a special theme selected to help walk thru some training...
Set your theme back to balanced3-26-2018 7-55-05 AM.png...
Matt Johnson
Teamcenter 10.1.7
Re: Smart Dimension
Welcome.
Glad to be of help.
