So this just happened, all my dimensions in a draft display as "V"*****, even on older drawings
So this just happened, all my dimensions instantly turned into V**** right after I placed a dimension. Now every drawing regardless of when it was made displays and prints this way.
Any Ideas on how to fix this?
Re: So this just happened, all my dimensions in a draft display as "V"*****, even on older
Never mind, I figured it out
Right click on the dimension and hit "show all values", It was on "show all names"
You lucked out there. Right-clicking on a problem area is a good idea when you are clueless.
