Solid Edge 2019, missing toolbar
Where is the toolbar?
Solid Edge 2019
7 REPLIES 7
Re: Solid Edge 2019, missing toolbar
Looks like an issue with your installation.  Are you using a custom Theme?  If so set to a delivered Theme and if that doesn't resolve it, maybe a clean re-install?
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
Changed the Theme, did not work.
I will try a clean re-install now.
Solid Edge 2019
I restarted  Solid Edge and now I have the toolbar, strange.
Solid Edge 2019
Hi @Geir-Petter
I had the same issue and behaviour, but I have forgotten to delete/rename my custom toolbar setting under %appdata%
So SE did a copy of all toolbars from "unigraphics\...." to the new folder Siemens\...
So I stopped SE, renamed that folder and started again, where all toolbars/menu where visible again
Wolfgang
Could it be this one?
Solid Edge 2019
Hi @Geir-Petter
Yes this exactly is the correct folder!
I assumed that everybody knows the Windows variable "%appdata%", which brings You to that folder when be entered in the command line of the explorer.
Sorry for that!
And this is/was the place where SE saved the user custom settings for his user interface.
And when this folder of an old version is in place, SE copies it when starting a new version the first time.
But then - and this was the case very often - people were missing new features and function in their multi tab menu, or I suppose, had this strange behaviour, we have seen when starting 2019 the first time.
Wolfgang
Hi Wolfgang,
This solved my problem.
Thank you!
Cheers,
Geir
Solid Edge 2019
