Solid Edge 2D Free ST10 auto dimensioning
Where is that option that I can switch auto dimensioning off when I draw lines?
4 REPLIES 4
Re: Solid Edge 2D Free ST10 auto dimensioning
Hi there @Solid_Designer,
In IntelliSketch Options......
Hi
I guess you mean in the sketch environment. You can find it under the Home tab in the Dimension group. The command is called 'Auto-Dimension'.
585 ST10 Win 7
In the Sketching tab select the IntelliSketch icon.
In the IntelliSketch window select the Auto-Dimension tab
Uncheck "Auto create dimensions for new geometry"
Select OK to close the window
Snap!
