Solid Edge 2D - insert holes from table?
Is this possible. Can I generate holes/circles from table with X,Y coordinates and diameter?
8 REPLIES 8
Re: Solid Edge 2D - insert holes from table?
Not out of the box.  You would have to write a program to do this. It's possible someone may have written something but I do not know of any.
http://Grundey.blogspot.com
Ok thank you for your reply. If anyone is interested in developing such a link for me I am willing to pay for this.
Hi @KennyG
Hi @methosmen
can not confirm this info 100%
Just did a 2D drawing only with a rectangle and 3 circles and created a hole table with exactly the same result as I assumed to get
Wolfgang
@hawcad,  I believe @methosmen is asking for the ability to place circle geometry on a drawing by reading in a table of locations and diameters.
HI @KennyG
OK, sorry again for missunderstanding what the request is.
I have read "holes and table" and - Yeah - thought this only can be a "hole table"
What a short word can make a difference?
I have written a macro a couple of years ago, where You were able to create several circles with center coordinates from a text file (x,y).
But this only was intended to be executed from within a profile sketch in part.
Wolfgang
Honored Contributor
Honored Contributor
It could be done, but only for a fixed number of holes like this:
Draw a sketch with a bunch of dimensions for each center and dia. Then link those dimeinsion from a spreadsheet.
I don't think there is any way to do this for a varrying amount of holes.
Hi Wolfgang.  Would you be willing to share this macro?  It is exaclty what I require.
Thanks, Tony
Hi @a2proven
of course, no problem.
But You please must wait until I will be back in office.
Just don't forget it and don't forget to remind me!
Smiley Wink
Wolfgang
