Solid Edge Community Guidelines
Community Manager
If you're new to the Solid Edge Community, welcome!
Here's everything you need to know about using the Community.
Getting Started
Solid Edge Forum Guidelines
This forum is dedicated to all things Solid Edge. If you have a question about customization or programming, please check out our Developer Forum. Posts about paid applications that supplement Solid Edge should be shared to the Solid Edge Apps MarketPlace.
When posting to the forum, please use a label to indicate which version of the software you’re using. This helps you get an answer faster. You can subscribe to labels to follow conversations on a specific topic.
Play nice. We’re all here to learn. No one likes to get their feelings hurt.
Participate. Jump in and contribute to the discussion. If you like something another community member has to say, give them a kudos. If someone answers your question, mark it as the accepted solution so others can find it.
If you have comments, suggestions, or you need help navigating the community – contact your community managers - myself (@AnthonyJohnson) and @ErinDaly.
Anthony Johnson
Community Manager
Re: Solid Edge Community Guidelines
