Solid Edge Download
Not applicable
Hi Everyone,
I have downloaded the program to my laptop...But the installation wizard for Installshield stops with about 75% completed and gives me the following Error message:
Error 1330 A file cannot be installed because the cabinet file
c:\Documents and settings\cameron\...\lightw~1.cab. Has an invalid digital signature.
This may indicate the cabinet file is corrupt.
Error 3 was returned by Winverifytrust.
Does Anyone have any ideas?
Thanks, Cam
Re: Solid Edge Download
Not applicable
Bad download perhaps... Try downloading it again.
Also, did you disable your virus scanner before attempting to install?
http://grundey.blogspot.com
On 9/14/2011 2:33 PM, csdb719@sbcglobal.net wrote:
> Hi Everyone,
> digital signature.
> Thanks, Cam
Not applicable
Thanks Ken. I will start with the Anti Virus, then maybe another download tonight.
Cam
I would suggest the following before reloading Solid Edge:
1. Make sure UAC is turned all the way down
2. Uninstall Solid Edge
3. Delete any Solid Edge folders you see in the Program Files and Program Files (X86) folders of Windows Explorer.
4. In the Registry Editor, look for and delete any Solid Edge registries found in HKEY_CURRENT_USER\Software\Unigraphics Solutions and HKEY_LOCAL_MACHINE\Software\Unigraphics Solutions. (Be Careful – only solid edge related ones)
5. While still in HKEY_LOCAL_MACHINE\Software, expand the Wow6432Nodefolder and delete any Solid Edge related registries found under Unigraphics Solutions folder.
6. Reboot (very important step)
7. Reinstall Solid Edge
8. Confirm license file is in place
Not applicable
Hi, have exactly same problem than Cam and tried all Ken & Stainbro suggestions w/o success. Can someone help please?
Thanks.
Pedro
Not applicable
Hi again. Tried to install on other XP machine and installed without issues, so my problem is in OS. Regards.
Pedro
