Solid Edge Draft Template
Builder
Builder
So I would like to know how to update my list up templates in SE ST7, under the Create title when SE is first booted. I want my newly created .dft file to take the place of the current .dft file. Any ideas?
Re: Solid Edge Draft Template
Template locations are generaly under program files/solidedge/template
Make a template, save your file into that location, and then when you hit "Edit Create Options" and go to "Browse" you should see you new file.
Are you looking for the Edit List option below the list?  There are a lot of options for creating custom templates, and some good blog posts about how to make them work for you.
HTH,
Jason
Builder
Builder
I was not. I figured it out. I wanted the list you pointed out to display my new draft. So this is what I did. I placed the new .dft in c/program files/solid edge st7/template/"company template folder"/ and it appeared. Thanks for the speedy reply.
