Solid Edge Free 2D
I have ST9 already running on my system.
Please let me know, how I can install  Solid Edge Free 2D on the same system.
thanks
Deepak
Re: Solid Edge Free 2D
Solid Edge and Solid Edge 2D are the same program -- it is the license file that determines which program is run.  If you already have Solid Edge installed, then all you need to do is replace your existing Solid Edge license file with the free 2D license file.
Consider backing up your existing Solid Edge license file before you replace it.
