Solid Edge Help Language
The "Learn Solid Edge" links from the Start Page of my Solid Edge 7 English Version suddenly started pointing to Portuguese Pages.
For example. The link "Choose a Learning Path" points to the following URL:
https://docs.plm.automation.siemens.com/tdoc/se/107/help/#uid:index
How can I access the English Help Pages?
Thanks.
Rogerio
Re: Solid Edge Help Language
That link shows English Help for me so I'm suspecting it may be the language setting for either your OS or asomething with your browser.
http://Grundey.blogspot.com
In Internet Explorer...
Internet Options -> General tab -> Appearance -> Languages button
Select Add...
Add your desired language. In your instance, add English.
Once your desired language is added to the list of Language Preferences, "Move up" your desired Solid Help Help documentation language to the top of the list.
Refresh/reload the Solid Help documentation.
Thanks a lot.
