Solid Edge Home Use License
is it still possible to get a home use license and how do i go about getting one?
John
Re: Solid Edge Home Use License
You have to log into the account with license number, or webkey, or sold to, or whatever they call it, and then you can setup home and travel accounts.Not sure, is it Classic and Premium that allows this?
That wasn't much help was it? Sorry, I'd have to go back and do it again to have the exact terminology.
well, that's a start. should i download Solid Edge first?
Last I checked you can't get a home use license file from GTAC site, you must talk to your reseller. Remember travel license is limited to a certain amount of days a year.
-Craig
I guess that home licenses are available for north-american based customers only. Other "B-series" customers can get a travel license only.
____________________________
http://www.stimarchetti.it
Design of automation
Hi John,
Home use licenses are still available to Solid Edge customers - we are a reseller in the UK and frequently provide our customers with them.
Generally, this will not be enabled by default in your WebKey account and you'll have to ask Siemens to enable it for you, if you are elegible - you can submit this request from your webkey from here:
https://webtac.industrysoftware.automation.siemens.com/qtac/index.php5?lang=en
If you do have a reseller though, it's probably a good idea to get them to do it for you Smiley Happy
OnePLM - Siemens Platinum Business Partner
http://majentaplm.com/
