Solid Edge Mold Tooling advises
Hello everyone,
is there any advises how to fix the following problem?
This is the part
Re: Solid Edge Mold Tooling advises
I don't see a problem.
Hello DGMC,
The parting surface looks mess up there Smiley Happy
@Destian,
I know it's a little bit late, but if you have any kind of doubts about Mold Tooling, you can send me the part under disclosure and I will try to prepare a workflow document on how to create a parting zone for that part.
In your specific case, I would have probably used the EXTRUDE offset instead of the LOFT.
