Solid Edge OpenSave, How can we get the dimention updated rather than showing ''value changed''?
Solid Edge OpenSave left changed dimention as ''value changed''.
How can we get the dimention updated rather than showing ''value changed''?value changed.jpg
8 REPLIES 8
Re: Solid Edge OpenSave, How can we get the dimention updated rather than showing ''value changed''?
Have you checked this setting:
That's strange though. I've never seen the tracker put that in the dimension value.
Bruce Shand
This is happening to me now. It has nothing to do with OpenSave, as I didn't use it for this at all.
(view in My Videos)
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Hi @nominus38
same as so often:
is it possible to upload draft and part?
Wolfgang
@hawcadnot this time around, due to who the customer is and how protective they are of the design on this unit.
Solid Edge 2019
We have same problem.
what is the solution to write the dimention number?
Hi there @Tibor1337,
Not seen this happen myself.....BUT, what is you Solid Edge version number? [mine: 219.00.05.007] Plus, on what Windows version?? [mine: Win10Pro #1809]
I dont know how to solve the problem.
i think about a regedit or microsoft visual update.
i try to download 2019 open save. ST8 open save with BOM but doesnt work the dimension update.
Solid edge (version: 109.00.02.004 x64)
Windows   (10 Pro 1809)
