Solid Edge ST6 - Maintenance Pack 12 Announcement
Siemens Legend Siemens Legend
Siemens Legend
January 5, 2015
Dear Solid Edge Customer:
The latest Maintenance Pack (MP12) for Solid Edge ST6 is now available for download.
The Solid Edge Team
Release Notes:
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
      File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: for the web interface.
Or send an e-mail message (message and subject line should be blank) to:
This Maintenance Pack addresses the following PRs:
PR 1128586: Alternate assembly problem when closing without modification
PR 7238658: When using a specific fitting the adjacent pipe does not reach the coordinate system it should
PR 7247982: Mirror Assembly fails with “Operation Unsuccessful" message
PR 1992054: Translating out drawing views with assembly features hidden not correct
PR 7250097: Wrong hatching while zooming or moving hatch is there or not
===Part/Profile/Sheet Metal===
PR 7240989: Problem with BlueSurf with tangent end conditions creates dependency loop
PR 7244504: Trim surface features are losing regions to remove on re-compute
PR 1992524: Too long time when saving a new draft file in Insight
PR 1995321: CPU intensive time during Deep Tree Generation
===Solid Edge Embedded Client===
PR 7204751: Different list of Projects displayed in Rich Client vs. SEEC CPD
PR 1129564: Save As incorrectly displays Item Name in CPD when linked Item Rev exists
PR 1991413: SolidEdgeTranslationServices.exe cannot run multithreaded
PR 6997635: Save As on Solid Edge Draft in SEEC gives incorrect filename
PR 7182243: Replace one revision with another errors
PR 7225135: Revise creates wrong dataset name when specific custom property exists
PR 7240860: SEEC is downloading templates that are currently up-to-date in the cache
PR 8250584: Localized ATTI unable to successfully validate and upload files
PR 8252358: Replace with released component of null mandatory attributes results in error
PR 8252609: Save As with Structure Editor save a wrong item name
PR 8254839: Localized ATTI unable to display property columns for certain dataset types
Fred White
Siemens PLM Software
