Solid Edge ST6 - Maintenance Pack 13 Announcement
Siemens Legend Siemens Legend
Siemens Legend
February 13, 2015
Dear Solid Edge Customer:
The latest Maintenance Pack (MP13) for Solid Edge ST6 is now available for download.
Sincerely,
The Solid Edge Team
Release Notes:
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
      File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe.plm@siemens.com
This Maintenance Pack addresses the following PRs:
===Assembly===
PR 7250477: Show Only command does not work on a part in a large assembly
PR 7286828: modification during IPA is dismissed if you cancel the delete/suppress-dialog in assembly
===Draft===
PR 1937906: Text within a block with orientation Center Left exported with wrong position
PR 1989981: SE ignores the defined Font Mapping on export of Textboxes as MTEXT
PR 7272043: In Text box properties "Justification" value is not correct. Please fix in ST6
PR 7223230: Some text not searchable when saved out to PDF
PR 2247261: parallel dimensions in ST3 when opens in ST6 the dimension positions are changed
PR 2249099: Dimensions move when you open the provided daft in ST6
PR 2249101: Moving one dimension causes placement change in another
PR 7276910: Grid-Origin moves after switching sheets
===Insight===
PR 7207681: Non-string properties are deleted from files
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 7195427: Opening file with custom status of 31-Locked displays incorrectly in Read Only
===Solid Edge Embedded Client===
PR 7263188: Property not updated in draft because reverse property sync of children skipped
PR 8250584: Localized ATTI unable to successfully validate and upload files
PR 8252712: Add to Teamcenter crashes when uploading assembly
PR 7169854: Item Name in Solid Edge CPD not synchronizing between Part and Draft file
PR 7219661: Density for selected Material on SEEC CPD does not match SE Material.mtl
PR 7278961: CFG file is not being uploaded to TC for an assembly having no links or component
PR 7278977: Draft image files such as emf, jpg, bmp etc. are not carried forward during Revise
PR 7250239: Mandatory attribute not being set during Solid Edge Draft save
PR 7251662: Bad performance in new SEEC implementation.
Fred White
Siemens PLM Software
