Solid Edge ST6 - Maintenance Pack 14 Announcement
Siemens Legend Siemens Legend
Siemens Legend
April 28, 2015
Dear Solid Edge Customer:
The latest Maintenance Pack (MP14) for Solid Edge ST6 is now available for download.
Sincerely,
The Solid Edge Team
Release Notes:
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
      File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe.plm@siemens.com
This Maintenance Pack addresses the following PRs:
===API===
PR 8252701: Assembly Relations are lost when using "TranslateMultipleOccurrences"
PR 7325992: SetPropertiesInfo API does not allow the dataset name column to be cleared
PR 1996278: Unable to access edgebar features via API
===Assembly===
PR 1993287: Occ prop dialog shows wrong rotation values
PR 7295498: Parts jump on update all
PR 1992274: Changes made with Physical Properties not handled correctly
PR 7286889: physical properties calculation saves material to part
PR 7288288: Handle points of frames moved after Update all links done
PR 7217433: Assembly constraints become corrupt when using MultiCAD driven references
PR 7329238: Files opening with Read Only status when they are available
PR 8700613: Part copy needs update without model's change
===Draft===
PR 1991000: When saving to Dwg, 'Solid Edge ISO' textfont is not converted to textfont 'Aria
PR 2250493: abort when un-breaking views in some cases
PR 7212177: a drawing view did not depict correct assembly feature in some cases
PR 7216837: In ST6, the text "jumps" to a higher position in the callout box
PR 7300949: Wrong dimension value for tangent dimension
PR 8261329: crash while using a new configuration file for a specific draft to dxf export
PR 7288091: DV become out of date, once an assembly has been opened
PR 7335228: Opening a DFT file crashes Solid Edge
===Part/Profile/Sheet Metal===
PR 7149122: Incorrect scaling applied for Part Copy if value is not followed by Enter or Tab.
PR 7234789: Expression in Variable table fails during attempt on Sync edit
===Insight===
PR 8261192: Insight Search lists all documents twice after an upgrade from V20 (WSS2) to ST7
PR 7332037: Getting a “Cannot download a document" message
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 7285591: IE10 - Crash seen on sending any SESP objects to Relation Browser
===Solid Edge Embedded Client===
PR 6997635: Save As on Solid Edge Draft in SEEC gives incorrect filename
PR 7271453: ATTI French consistently crashing
PR 7305483: Solid Edge Model file remains checked out to me while the Draft is checked in
PR 8254839: Localized AddToTeamcenter Interactive unable to display property columns for certain dataset
PR 8263114: AddToTeamcenter interactive doesn't honor the preference SEEC_property_item_name
PR 7332854: does not assign project info, correctly during a revise operation
PR 7334006: Local BOM Precision Override
PR 7324478: Save As copies ItemRevision name from source to new object in 10.1.3
PR 7341209: Item Numbers in SE Assembly are not synchronized with Find Numbers in TC
PR 7355760: Revise generates Partial Error
PR 7283519: ASM occurrence property, Item Number are not being maintained from the TC BOM
Fred White
Siemens PLM Software
