Solid Edge ST6 - Maintenance Pack 4 Announcement
Siemens Legend Siemens Legend
Siemens Legend
January 27, 2014
Dear Solid Edge Customer:
The latest Maintenance Pack (MP4) for Solid Edge ST6 is now available for download.
Sincerely,
The Solid Edge Team
Release Notes:
--- Maintenance Pack Policy --
We release Maintenance Packs for CRITICAL items only. Maintenance Packs are available
up to a maximum of 15 months following the release date of the English version. The
release date for Solid Edge ST6 English was 7/19/13, making the Maintenance Pack
cutoff date 10/19/14.
Download Location:
ST6 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtmlfor the web interface.
Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe.plm@siemens.com
This Maintenance Pack addresses the following PRs:
===API===
PR 2226134: Need a sample to Control the mesh & contour display through SE API
PR 6931965: Query on HolePtr.GetHoleData() raises exception with Synchronous mode ThreadHole
PR 6941513: Event notification was needed when an occurrence was renamed.
===Assembly===
PR 1963509: Problem when modifying with ST5 piping route made in ST3
PR 2805983: Unable to pattern parts using a sync part inside a subassembly
PR 6945352: Abort when opening this assembly
PR 1962276: Assembly Features not visible, recalculating destroys all
PR 1963404: FOA Assemblies has very long network save time
PR 1964998: Crash when edit opening a part in certain circumstances
PR 2230033: JT open in solid edge assembly shows scattered parts
PR 1964934: Select all occurrences did not work properly for sub-sub assembly
PR 6980164: Unable to run SEAdmin.exe (New SEAdmin.exe needs to be downloaded)
===Draft===
PR 1960219: Apply PMI model view and perspective is turned on although not saved with view
PR 1961692: Dimension feature callout does not work on section view
PR 1962484: reproducible crash inside cutting plane definition
PR 6954876: Warning message shown while placing DV for this case
PR 6956481: Draft file aborts when opened - Please repair in ST6
PR 6961614: Incorrect hole size when hole was changed from tapered to simple
PR 6975811: Callout and balloon attachment problem
PR 1967132: Enable shading options on 2D views to allow shading to be removed on converted drawing views
===Part/Profile/Sheet Metal===
PR 1951995: Pathfinder in document view will change from selected to de-selected
PR 1958710: Applying face style with transparency result is black
PR 6956766: Change to bend radius for gage in material table not maintained
PR 6962591: Part color changes when exiting Simulation results
PR 6975794: Existing Thread features fail in ST6. Unable to place Thread features on holes
===Insight===
PR 6927845: Slow to open in Revision Manager when components have families of parts.
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 1940849: Synchronize do not create the file PDMPropertyInfo.xml
PR 1959916: Experiencing poor open and save performance with large assemblies in SESP
PR 6878737: Need a message returned that notifies the user a file did not get checked
PR 6958980: Checked out part in cache, undo check out from client2; client1 sync
PR 6967077: Set Revise, Make\Buy & Supplier columns are not editable
PR 6967175: Open Assembly will crash Edge at download stage; try to reopen shows transaction error
PR 1944664: Open draft file do not download all files in the folder cache
PR 6929224: The Solid Edge SP Server cache has not been configured correctly
PR 1944391: Times to check-in or saving is too long
===Solid Edge Embedded Client===
PR 6973668: Rev # value as entered is not used when mouse hovers over drop list
PR 1960094: Multi-CAD take ownership with revision naming rules not incrementing to next rev
PR 6896782: SEEC: Enter key does not perform search
PR 6961320: Reimport will not run with use existing released dataset
PR 6964153: Consistently run Validation as files are loaded
PR 1921612: "Save as" from SESE into an existing item id doesn't copy the BOM
PR 6973687: Second 'Save As’ leads to 'Missing value for required properties
PR 6974215: Drawing Number property is getting reset
PR 6974240: Wrong revision numbers for Save As and Revise
PR 6975995: Save As is using the wrong revision value in the dataset name
PR 6976677: Save as and Revise at the same time allows the Item ID to be modified
Fred White
Siemens PLM Software
