Solid Edge ST6 - Maintenance Pack 5 Announcement
Siemens Legend Siemens Legend
Siemens Legend
March 3, 2014
Dear Solid Edge Customer:
The latest Maintenance Pack (MP5) for Solid Edge ST6 is now available for download.
Sincerely,
The Solid Edge Team
Release Notes:
--- Maintenance Pack Policy --
We release Maintenance Packs for CRITICAL items only. Maintenance Packs are available
up to a maximum of 15 months following the release date of the English version. The
release date for Solid Edge ST6 English was 7/19/13, making the Maintenance Pack
cutoff date 10/19/14.
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
      File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtmlfor the web interface.
Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe.plm@siemens.com
This Maintenance Pack addresses the following PRs:
===API===
PR 6988512:  Abort at ModifyOffset::GetArrayMemberIndex—Crashlog
===Assembly===
PR 6983036: Problem with angle relationship behavior when changing from Fixed to Range
PR 1955047: Opening FOA file and closing without save touches the FOA file
PR 1964937: Assembly performance decreases when parts are not modified by assembly features
PR 6983036: Issues with sixth angle bounded dimensions
PR 1966217: Solid Edge can't mesh model and crash while trying to edit material
PR 2806276: Delay when placing parts in an assembly
PR 6982299: Update All in physical properties manager is not updating the mass
PR 6988513: Abort when selecting visible parts that are sectioned
PR 1965492: Part "dirty" directly after opening assembly
PR 1965612: Not able to open assembly on Windows 8
PR 1970822: Conflicting relationships when replacing an assembly by another member of FOA
PR 6940390: Subassembly not displayed in top level when opened Hide All and then Show all
PR 6944055: Mirrored components not displaying in assembly pathfinder
PR 6988397: Solid Edge locks up when inserting a part
PR 6992064: Unable to save file after Undo of a pattern if pattern of frames
PR 6993707: Customer has a large assembly file of a plant (building) he is making the piping
PR 6999238: Unable to apply relationship between face and ref plane or CS plane
===Draft===
PR 1968174:  Dimensions (by 2 points, set in ST5) will be oriented hor./vert. in ST6
PR 1968968:  Solid Edge stops working
PR 2229114:  Callout text moved when draft exported to .dwg
PR 2229124:  Callout Text "%CL" in not supported within AutoCAD translation
PR 2231479:  If V15Draft is opened by ST4; the value of a size will change
PR 6966839:  SE Options: modified colors revert to default if not changed in next instance
PR 6971410:  Stack dimension is not reorienting the affected dimensions
PR 6985115:  While deleting Sync dimensions file aborts
PR 1970058: Embedded MS Word Document (.doc MS Word 97 - 2007) not imported
PR 1970233: Some bend centerlines were not showing up in flat pattern view
PR 6967180: Shading for drawing views not displayed in viewer data
PR 1962317: Abort, while creating DXF-File
PR 1965895: Please repair this draft in ST6
PR 6976651: Callout text is moving causing the leaders to stretch
PR 1967770: Can't open file. Please repair in ST6
PR 1972398: session aborts while deleting a drawing view
PR 6995551: Getting wrong results when using %RT in callout
===Part/Profile/Sheet Metal===
PR 6984405:  Integrate updated NX 9 adapter into ST6 MP5
PR 6997136:  Solid Edge Abort when using face relate to try to modify read-only Insight part
===Insight===
PR 6982533:  Insight Connect remains minimized when a new file is opened
PR 6946375:  Property Manager Error in View & Markup
PR 6916189:  Incorrect error given when attempting to revise component in released sub-ASM
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 1944664: Solid Edge SP- Open draft file do not download all files in the folder cache
PR 6976582: Cannot delete templates
PR 6991838: Structure Editor: Paste operation time increases with BOM lines
PR 6958476: Improve Web Client Performance needs to be back ported into ST6 MP
PR 6987436: Error messages seen while uploading large Robbins dataset using chunk size=100
PR 6997079: Cannot import this specific draft into the database
PR 1965289: Problem with Data Preparation Tools in German Solid Edge SP with IXT-StatusNr
PR 6997660: CPD loses information during save as and revise operations
===Solid Edge Embedded Client===
PR 1938118: SEEC Save As automatically assigns new Item to same Project as original Item
PR 1955619: Inconsistent read-only/checkout behavior in Open workflows
PR 1966989: No custom item types in CPD
PR 1966993: Unable to save SE dataset to empty item with custom item type
PR 1969514: Umlauts for LOV Attribute values are not displayed in Solid Edge CPD window
PR 6768788: In this workflow ASM file is open with file load failure. (Workflow specific)
PR 6970302: Edge crashes if double-click in an empty cell in Search dialog
PR 6989976: Back Port ST7 deviation D4110 Enhancements to Re-Import Workflow-AT2i to ST6MP5
PR 1961950: Cannot set default or select value for Boolean property upon initial creation
PR 1968462: Non-English AddToTeamcenter Interactive doesn't load itemid, revid, item name
PR 2229264: Paste operation time increase dramatically with the BOM lines
PR 6937930: Save As of assembly draft; opening new ASM shows file load failure (Tc10.1)
PR 1969451: LOV on object_name is not available in CPD window if perform Save As
PR 6983476: SEEC query double click not working correctly
PR 6990612: Incorrect document name formula is displayed after Assign All in RHS (ITA)
PR 6991647: With documented workflow the dataset name will not be named correctly
PR 6991864: The custom Item Name will get removed when auto assign during a save as
PR 6991919: If the property Pattern_ItemID is missing, then pattern will be empty
PR 6993380: Copy and paste "Revise" action in SESE causes a termination
PR 1966270: Replace Sub-Assembly with copy duplicate occurrences in TC structure manager
PR 2211862: SEEC "add to Teamcenter" failed when ST4 and TCX have attribute mapping
Fred White
Siemens PLM Software
