Solid Edge ST6 - Maintenance Pack 7 Announcement
Siemens Legend Siemens Legend
Siemens Legend
May 19, 2014
Dear Solid Edge Customer:
The latest Maintenance Pack (MP7) for Solid Edge ST6 is now available for download.
The Solid Edge Team
Release Notes:
--- Maintenance Pack Policy --
We release Maintenance Packs for CRITICAL items only. Maintenance Packs are available
up to a maximum of 15 months following the release date of the English version. The
release date for Solid Edge ST6 English was 7/19/13, making the Maintenance Pack
cutoff date 10/19/14.
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
      File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: the web interface.
Or send an e-mail message (message and subject line should be blank) to:
This Maintenance Pack addresses the following PRs:
PR 6988067: PropertyTableAttached Attribute gets Duplicated on feature removal
PR 6973019: SolidEdgeFrameworkSupport.Dimension GetRelated method crash in c# macro
PR 1970937: Part document becomes modified after calling API function CopiedParts->Count
PR 7104784: Dimensional edit moves matching hole in wrong direction
PR 1964973: When modifying piping route, the elbows come with a wrong orientation
PR 1973819: Bad Performance when deleting assembly features
PR 1973839: Close docking panes restored in new SE session
PR 1978273: File will not be saved, when saving from an assembly
PR 1979380: Parts are hidden after removing a part in a pattern of adjustable parts
PR 2229548: angle relation display not correct when hovering over the various angle types
PR 2237164: It takes too much time to open assembly
PR 2237304: Cannot delete mirrored assembly.
PR 6981399: Issue replacing adjustable parts and parts being over-constrained
PR 7109819: Assembly feature pattern fails after running the reduce feature scope utility
PR 1968991: Save as Image doesn't keep the destination within one file
PR 6986661: KeyShot freezes when rendering from Solid Edge
PR 1964690: Trim face command does not work on Mid-surface features in Simulation
PR 6994037: Torque load on a bolt pattern is not locating correctly
PR 1969480: insufficient connection after split path
PR 1976120: Using Zone makes SE hide other inactive parts
PR 7104885: When a mouse is set up for a Left handed user and placing assembly relationships fail
PR 1961227: Property Text "Menge" shows errors in German
PR 1968108: Drawing View caption fill enlarges
PR 1974592: File will not be saved, when saving from an assembly
PR 1978414: File cannot be saved under certain circumstances
PR 2230180: Drawing Views are not aligned correctly after undo of add break lines
PR 6930733: Text not exporting to AutoCAD correctly
PR 6982353: Italic font style lost on Export
PR 7116418: Dimensions jump when adjusting leader
PR 7125671: Create 3D, SE crash occurred after selecting sketch having angular chain dim
PR 2806623: shaded drawing views changing color after a view update
PR 1937906: Text within a block with orientation Center Left exported with wrong position
PR 1980551: Fill Color "none behaves different between MP4 to MP5
PR 6933885: Unable to finish Hole feature after removing some hole circles
PR 1982106: DWG File cannot be opened in
PR 2237388: ESKD caption line has incorrect width
PR 7125412: OLE objects import from ACAD all produce same data
===Part/Profile/Sheet Metal===
PR 1965290: Can't select edge after IPA edit
PR 1977548: API - Sheet Metal Neutral factor from Excel.
PR 1978433: reproducible crash during placement of round
PR 1978801: Cannot perform a flat Pattern on this simple part, but could in ST4, regression
PR 2231669: hole moving to wrong face after adding a cutout in sync model
PR 7129270: Wire frame displays as Visible Edges unless rotated
PR 2237063: Accept & Deselect buttons becomes gray out on changing option in Contour flange
PR 1980506: Send Command log does not work for the customer
PR 7132762: Incorrect position of part files when importing a X_T file
PR 7133311: Solid Edge stops working when publishing multi bodies
PR 1973022: Color manager doesn't work correctly with construction bodies
PR 1969680: Graphics Web Part control settings not working for 2D
PR 1969608: Web Parts are not working with SE Viewer only clients
PR 6946038: Slow Operation with FOP links and non-defaulted cache location
PR 2237612: Where used search returns "cannot connect to library"
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 1976391: Cannot delete a .zip saved to a Project using the "Create Package" command
PR 1954665: No linked part revisions visible for some projects
PR 7119355: Run Search from SE and the cache is cleared
PR 6792233: Crash while open in Editor in case of 32 bit office and 64 bit browser
PR 6974145: Send part having multi-body to Map view, switch to list view> SESP web crashes
PR 6998080: Import the specified draft file, error during creation of pdf file
===Solid Edge Embedded Client===
PR 1968466: Replace in TC Structure Manager not correctly syncing with SEEC
PR 1977862: BomView is missing if performing a SaveAs SE Assembly
PR 1978017: Cannot write on Object "SE_Attr0" with Class FormImpl (Form)
PR 6647182: component moves to origin when feature is deleted
PR 6953908: Second revise with secondary RNR places description in the revision field
PR 6958135: Add to Teamcenter Interactive aborts with shortcut command
PR 6997570: Unable to use a mapped drive for finding linked files with Add to Teamcenter Interactive
PR 7110974: CPD assign Item ID/Rev ID issues
PR 7111789: Find All Related Drafts fails and causes abort on exit
PR 7113380: unknown Teamcenter error trying to save a part to Tc10.1.2
PR 7120882: Import Solid Edge Templates fails when SEEC_ItemType* does not include Item
PR 6754049: Dragging unmanaged part into managed draft gives error message 3 times
PR 6944040: Unable to drag text from unmanaged dft to managed dft
PR 1980358: SESE not assigning Revision ID when single Revision naming rule used
PR 1980359: SESE linked file structures differ on subsequent opens compared to initial open
PR 1981108: SEEC - SE Interpart Draft Links Relation is not available in *dft.xml
PR 6944784: SEEC: search for part number finds no results
PR 6973867: Custom / required file property is not used in the right pane of dialog
PR 6985901: Add to Teamcenter Interactive does not pick up mapped attributes that are in the source file
PR 7130966: IPA into a part does not check out the part
PR 6968692: Unable to add a draft to a revised part
PR 6991146: User get suspend error while re-importing Par and DFT with Revise action
PR 7113920: Problem searching for Teamcenter numeric attributes
PR 1976797: Missing mother-child relationship link if opening only Child Draft
Note: User still needs to set debug registry key "SEEC_Draft_DisableExpandGRM" to 0, if they want to download all the relations as part draft open.
Fred White
Siemens PLM Software
