Solid Edge ST6 - Maintenance Pack 8 Announcement
Siemens Legend Siemens Legend
Siemens Legend
June 23, 2014
Dear Solid Edge Customer:
The latest Maintenance Pack (MP8) for Solid Edge ST6 is now available for download.
Sincerely,
The Solid Edge Team
Release Notes:
--- Maintenance Pack Policy --
We release Maintenance Packs for CRITICAL items only. Maintenance Packs are available
up to a maximum of 15 months following the release date of the English version. The
release date for Solid Edge ST6 English was 7/19/13, making the Maintenance Pack
cutoff date 10/19/14.
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
      File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtmlfor the web interface.
Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe.plm@siemens.com
This Maintenance Pack addresses the following PRs:
===API===
PR 1981253: Improved parameter validation in DrawingView.SetViewOrientation to make it simpler to use
===Assembly===
PR 6941314: No Sync Hole created from Assembly if “From-To” options is used
PR 1970098: Verify availability of fittings should be on for piping routes
PR 1978664: Assembling new parts into assembly is very slow
PR 1982364: Large number of Label Weld features slowing down graphic performance
PR 2238087: Poor performance placing parts and pipes
PR 1932984: user preferences create bad STEP files; existing user preferences create good STEP file
PR 1951871: Unknown error message when doing self-paced Frames training
PR 1982617: Entering values of XpresRoute Dimensions is not working properly
PR 7124418: Getting conflicting item numbers in Occurrences Properties
PR 7111238: Having trouble with reference axis of revolved assembly protrusions and cutouts
PR 1974979: Solid Edge stops working during edit cross section
PR 7109819: Too many parts removed from the "reduce scope" command
PR 7151658: When in XpresRoute, Frame centerlines showing
===Draft===
PR 1968432: Text moves when exporting to dwg/dxf
PR 1983642: Surface texture symbol gets distorted if changing its type
PR 2226440: Filling region causes crash
PR 2238216: Problem in callout Symbols when draft export to .dwg
PR 7125412: OLE objects import from ACAD all produce same data
PR 1934157: Text field position not correct when saving as dwg
PR 1966651: Text box moved when export in DWG if use base view scale is active
PR 1983965: Solid Edge will crash closing a draft
PR 2240191: Dimension leader line rendering/ display problem in Solid Edge ST5
PR 7117141: Dimension location changes after opening an ST4 Draft in ST6
PR 7138747: Edge crashes after this workflow using the Select Conductor dialog
PR 7145198: Converting detail view to 2D still has geometry linked to the model
PR 1984574: weld-feature will be treated as simplified
PR 7148392: multiline textbox is not exported to AutoCAD
PR 1983527: Item numbers not displayed in Draft correctly for some occurrences
PR 1985804: failed PMI dimension causes performance problem
PR 6982296: Duplicate symbols are displayed for a dia & Radial dimensions
PR 7141764: There is an unwanted line between primary and secondary caption
===Part/Profile/Sheet Metal===
PR 1960726: Save Flatten as dxf contains incorrect triangulation lines
PR 1974546: Bluesurf does not work
PR 1978123: Thin wall with unique thickness on a face removes this face
PR 1959945: ST6 IGES export different compared to ST2 IGES
PR 6916069: SE locks up attempting to place a PMI dimension on specific edges of certain models.
PR 2224006: The number of property records influence the performance
PR 2240489: [Preview] Button of "Simplify" is not updated
===Insight===
PR 1966027: Very long close time for revised documents
PR 7118248: Dragging parts into assemblies is too slow
PR 7138021: No mismatch error accessing an Insight server with a different version client.
PR 2239066: Recursive search not working with Insight on SharePoint
===Insight Connect===
PR 6797608: Cannot use measurement commands in View & Markup
PR 6750770: Part in subassembly displays incorrectly after being renamed in Revision Manager
PR 6699740: V&M: Commands in Windows dialog say they are unsupported from the dialog.
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 6956062: BOM Mismatch error message for the assembly is shown to the user
PR 7140912: Modifications to the sub-assembly and parts lost as part of left over processing
PR 1957225: Cannot run web reports - No report templates loaded for this site.
PR 6985992: Go to Location does not expand to object in CB if beyond first 50 objects
PR 7147354: SE SP-EC: Save As action do not populate document content type
PR 1984327: Number columns in custom group not syncing correctly between model draft pairs
PR 2239017: Cannot search object when using customize (Chinese) property name in SESP ST6
===Solid Edge Embedded Client===
PR 6999784: 'Use Designed Assembly' leading to a crash
PR 6740239: Copy Doc # to new filename does not work in SEEC Analyze
PR 6828049: Draft dimension do not rebind for driven reference
PR 6930639: SEEC_DrivenReference_DoNotCopy_Revise still linking MSWordX datasets.
PR 6931067: Opening an Asm which has NX Asm added to it fails to translate the NX Asm
PR 6953492: Error condition on CPD when using a Revision Rule
PR 6966608: Reuse of folder is not displayed, no error when invalid
PR 6971928: Save As- PDF for draft does not exist under new item revision
PR 6999304: Assembly structure does not get updated when revising added to TcRS dataset
PR 7136786: Errors on items owned by Global Multi-Site
PR 7140772: Crash when revising a part if OS user has read only to Solid Edge TcE hive
PR 1959607: Slow SEEC save when sub-assembly is released and part is modified
PR 6908067: Revise issues with SEv19 generated objects.
PR 6944729: AddToTeamcenter incorrectly changes the Item Type then fails to import
PR 7137797: Revise Assembly file cannot be saved error
PR 7137834: Draft values in CPD are not in synch with Part
PR 7144737: Duplicated text in named references filenames during SE Save As
PR 1943093: Multi-CAD with NX assemblies containing JT files not creating child data
PR 1976080: Naming rules does not work properly in CPD with special characters: ?,&
PR 6801680: "Missing value for a required property" when required properties have value
PR 1985154: License server - consuming SEEC license on PC without Teamcenter
PR 7147125: Material selected for new part does not appear in New Document CPD
Fred White
Siemens PLM Software
