Solid Edge ST6 - Maintenance Pack 9 Announcement
Siemens Legend Siemens Legend
Siemens Legend
July 28, 2014
Dear Solid Edge Customer:
The latest Maintenance Pack (MP9) for Solid Edge ST6 is now available for download.
Sincerely,
The Solid Edge Team
Release Notes:
--- Maintenance Pack Policy --
We release Maintenance Packs for CRITICAL items only. Maintenance Packs are available
up to a maximum of 15 months following the release date of the English version. The
release date for Solid Edge ST6 English was 7/19/13, making the Maintenance Pack
cutoff date 10/19/14.
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
     File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe.plm@siemens.com
This Maintenance Pack addresses the following PRs:
===API===
PR 1984564: Performance issues when closing assemblies while running a .NET Add-In in Solid
PR 1977548: API - Sheet Metal Neutral factor from Excel
PR 1982103: Create in Place within SE-assembly via API in ST6 is not working
===Assembly===
PR 1958586: part files in an alternate assembly are disappearing from a drawing
PR 1981356: Replacing parts positioned by coordinate system does not work systematically
PR 2239297: Assembly Parts are missing
PR 6956847: File cannot be saved message after undo
PR 6997722: Randomly parts will not be displayed
PR 6997726: Assembly is constantly out of date - axial lock rotation compute issue
PR 7158070: Revolved Cutouts and protrusions fail after an update All
PR 1982387: Assembly cannot be translated with SWX Data migration tool
PR 2225823: PMI translation from Solid Edge to NX via JT
PR 6983685: Unable to migrate drawings with multiple sheets
PR 7144924: Import JT/NX assemblies into a Solid Edge part file
PR 1989082: Assembly coordinate system geometry is not locating correctly
PR 2241662: Unable to select reference position in pattern
PR 1990638: Abort while rotating assemblies and using certain face style
PR 2236158: In Edit of Tube Options, properties should be disabled if the file is read-only
PR 7146234: Error: The part cannot be placed. Make sure it is not a Feature Library part
PR 7128225: Position of parts in ASM is incorrect after importing this JT
===Draft===
PR 1950112: Viewer data was not being stored in symbol files
PR 1968584: Missing break line for linear dimensions
PR 1978811: Pictures are moved when saving as DWG
PR 1982813: Problems with the new paste multiple command
PR 1987274: trim corner between two curves in ST6
PR 2234235: Copy and paste drawing view to new template stops Solid Edge working
PR 2237306: Position of dimension is changes when ST2 file open in ST6
PR 2239789: Pasted groups not displaying in EdgeBar group tab
PR 7155023: Limit tolerances values are not being translated to Draft
PR 1987997: Drawing view creation time is slower than ST4 for large test cases
PR 6731742: Can't export to AutoCAD
PR 1976952: Expanded text box if fill color is set to white and multiline text is exported
PR 1990341: Company LOGO will be drawn incorrect
===Part/Profile/Sheet Metal===
PR 6384133: Feature Identification on SE model gives all double THREADED_SIMPLE_HOLE
PR 1985786: Need to identify existing sheet metal files that have incorrect flat features
PR 1989296: Flat pattern with chamfers is broken
PR 2242171: Improper positioning of Custom fitting using fastener system for thru hole
PR 7114815: Part fits real small
PR 7124313: Problem creating a draft bend centerlines do not display
PR 7143479: Problem flattening a part with an arc
PR 7146696: No shading on construction surfaces difficult to see edges when rotating
PR 7160250: Sheet metal file aborts after flattening
PR 1983372: Hole feature comes into wrong position, when modifying length of a flange
PR 1986570: Impossible to update a Part with FOP Part Copies permanently
PR 7156062: Setting to use Custom formula PZL is not retained
PR 7162813: Getting a crash on a specific workflow
PR 7165114: Import faceted JT in Sync Mode: - File is not opened automatically in ordered
PR 7164362: Profile region performance issue when many coincident faces exist
PR 7164811: Different results when doing transform to when part is a sheet metal part
===Insight===
===Insight Connect===
PR 7162482: Fixed a problem with DocControl users can't "Set action to update" on released assembly files
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 1932816: Close file does not release memory until SE is closed
PR 1970143: Assembly overwritten by an older version
PR 6980230: Cannot save a draft file
PR 7139734: Need to clear IE cache to see expected results for Reports
PR 7153340: Having many cases of being unable to Save and or Check in files
PR 7158955: Sheet Metal: Save As and Revise action closes SESP, process runs in background
PR 7161347: .CFG files are not saved when its .asm file has a released status
===Solid Edge Embedded Client===
PR 1966552: Cannot create new Items from Solid edge when forms are hidden
PR 1975448: Save As not assigning Item ID naming rules correctly
PR 2239328: Localized TC attribute mappings cause failure to create new items
PR 2241546: Unable to create Item after upgrading TC 8.3 to 10.1
PR 2808316: Search does not works when Windows date format is set to Portuguese
PR 6904077: AddToTeamcenter application says file is imported to TC but file does not find in TC
PR 6925278: SESE not displaying mapped attributes for columns that are hidden when file open
PR 6997517: SESE crashes when creating new item with Meta Model properties
PR 7118828: Property mapped across a relationship that does not exist, is returning the user
PR 7139178: Save As does not always honor revision naming rule
PR 7159895: After IPA Part file becomes read-only
PR 7161913: Suggestive LOV value not synchronized on Upload CPD
PR 7162528: Linked files from IPC of Assembly is not always copied to SEEC Cache
PR 7162750: SEEC hangs after hitting Help button on download file dialog
PR 7164152: Teamcenter Item Type is not populated in SE files migrated from TcE
PR 7164453: A managed NX Part CV JT is not opened in SEEC using Part template
PR 7164459: New version available status shown for driven reference ASM
PR 7123779: SESE has the NR pattern field disabled doing a revise of a part
PR 7164227: Document Name Formula cannot be set in SE Draft (works in SE Assembly)
PR 7164247: Drawing View Tracker behaves differently in managed vs. unmanaged mode
PR 7164336: Rename in SE Assembly Pathfinder removes Document Formula Name - can't reset
PR 7164973: Project ID Assignment on CPD must be cleared for both the model and the draft.
PR 7167445: No naming rule in CPD when doing a save as with migrated data
Fred White
Siemens PLM Software
