Solid Edge ST6 activation problem
Hello, I have a problem activating my ST6 version of Solid Edge. It accepts the license number (academic) but as soon as i click ok it suddenly closes and when I try to open it again it displays the error message in the image. I tried to reinstall it but nothing changes.
Re: Solid Edge ST6 activation problem
Community Manager
@Coyotek96
  • Please forward me the Student registration email that you received from us.
  • Please send me your SELicense.dat file (located in your ST6/Program folder). Ensure the name of the file is 'SELicense.dat' where 'SEL' in uppercase letters.
  • Please send me a screenshot of your License Utility dialog poluated with the 12-digit license code you received in the registration email from us.
  • Also please indicate the folder to which you installed Solid Edge ST6.  It should not be installed to a folder with "special characters" such as accented characters (e.g., "å").
 Laura
watson.laura@siemens.com
Re: Solid Edge ST6 activation problem - studient version
Hello Smiley Happy
I have a problem to activating my ST6 version of Solid Edge (studient version).
It can't accepts the academic license number. I can't select "OK" after typing the 12-digit license code i received in the registration email from you.
The 12 -digit code is the follower = xxxx
Please find screenshot in attache file, you can see "OK" is not selectable...
- I have corrected "SEl icense.dat" => "SEL icense.dat"
Thanks in advance
Anthony
Siemens Legend Siemens Legend
Siemens Legend
Hi @Tony-01
You are entering the wrong activation code.  The ST6 code is at the bottom of your registration email (in the “Note 1” paragraph).
Melanie
Hi Melanie Smiley Happy
Thank you very much for your answer Smiley Happy
I tried to enter the Good code (in the “Note 1” paragraph), i can selected "OK"... Smiley Happy
But a new message appears.... please see on attache file...
Anthony
Siemens Legend
Hi @Tony-01
Please email me directly at melanie.baeske@siemens.com, and we'll work this out offline.  I am thinking that you have write-access issues when the system is trying to save your license file.
Melanie
