Solid Edge ST6 student activation error
I've just installed SE ST6, entered the activaton code, but when I press OK, the program closes, and nothing happens. When I try to open Solid Edge an error messahe shows up (see attached screenshot), and, when I press OK, the activation form shows up again. Can someone help me?
Re: Solid Edge ST6 student activation error
Hi there,
Seems to me like the activation code you have used has probably expired....got through the signup process again, to recieve a NEW code.
Do you know how to get to the "Solid Edge - License Utility" to apply it?.....[in "All Programs" list]
Solid Edge ST10 [MP7] Classic [x2 seats]
I've had the same problem and tried to get a new activation code by re-registrating, but i only got the same code in a new email. (maybe from same IP adress i can get the same code). How to solve this problem?
So, I've found the solution. You have to enable Solid Edge, and the activation program SELicWiz.exe in Windows Firewall. Then run everything as Administrator.
