Solid Edge ST7 - Maintenance Pack 1 Announcement
Siemens Legend Siemens Legend
Siemens Legend
September 26, 2014
Dear Solid Edge Customer:
Solid Edge ST7 Maintenance Pack 1 for Solid Edge is available for download.
Sincerely,
The Solid Edge Team
Release Notes:
Maintenance Packs are released for CRITICAL items only. Maintenance Packs are available up to a maximum
of 15 months following the release date of the English version. The release date for Solid Edge ST7 English was
08/08/14, making the Maintenance Pack cutoff date 11/08/15.
In order to deliver the first ST7 Maintenance Pack in a timely manner, ST7 Maintenance Packs will continue to
be delivered using RTPatch technology and will require a complete uninstall of Solid Edge in the event a ST7 MP
needs to be removed.
Download Location:
ST7 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST7/Maintenance_Packs/
Installation:
Maintenance Pack Executables (.exe files) patch existing product dlls. Maintenance Pack executables
are all inclusive and can be installed on top of a base release or any released Maintenance Pack.
Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be
uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
This Maintenance Pack addresses the following PRs:
===API===
PR 7175283: Fixed length key point curve API does not work when curve goes thru key points
===Assembly===
PR 1994198: Impossible to select component in frame application
PR 7171757: Pipe component (axis) is not aligned with 3D sketch element on edit of Pipe Rout
PR 7173742: Enclosure does not update after moving parent component
PR 7173809: Assembly Feature does not update after Drag Comp
PR 7174425: Solve behavior changed for some assembly connect relationships
PR 7175178: Crash in assembly frame environment when SSD file is renamed
PR 7177852: Lower PathFinder shows Assembly Feature driving part file
PR 7178804: Need to support NX 10 created JT files
PR 1984803: Failed assembly relationships when opening some alternate assembly files
PR 7181086: Placing adjustable part in assembly crashes Solid Edge
PR 7183520: Hidden reference planes display when they shouldn't
PR 7187374: Crash when duplicating an adjustable assembly
PR 7187548: Abort when certain patterns are edited
PR 7189285: Fence selection performance issue with Steering Wheel enabled in large assemblies
===Draft===
PR 1989738: deleting a detailed drawing view leads to a crash
PR 1993512: Grid origin moves when opening previous version file.
PR 7174232: Edit Links change source was disabled if the linked document was not loaded
PR 7176351: Alt moving coordinate dimension not working with dimensions in both directions
PR 7177052: Lock dimension button is no longer disabled after selecting edge
PR 7175214: Coordinate dimensions cannot be aligned in this case
PR 7178804: Filled fonts" polyline representation not supported on import
PR 7185254: Cannot disconnect leader if attached to callout (preserves associativity)
PR 1986615: Cannot delete link from draft file
PR 1996610: Dimension Style with ',' will not be exported to DXF
PR 1997629: Certain Files crash ST7
PR 7190079: Copying views that have display depth specified
PR 7192924: DECs don't show up for rectangle sketch elements when using hot keys
===Part/Profile/Sheet Metal===
PR 1844241: Synchronous edit succeeds only with smaller modifications
PR 1991815: Flat Pattern fails, if using DIN.PZL instead of Standard Formula
PR 1992122: Cannot create a Flat Pattern of a Family of Part members created in Part
PR 1994161: Database for Holes does not work with Open Office as the standard program
PR 7143560: Can't create a ruled surface on my part
PR 7159816: Importing specific Catia V4 file in ST7 is slower than ST6
PR 7167802: Thread button is selectable when editing holes with not-found DB
PR 7171794: Regions are getting created from the protrusion faces having 3D sketch in it
PR 7172172: Invalid DB file allows selection of hole types
PR 7173598: Abort when in Etch command and select text profile then Pan the view and RMB
PR 7173696: Cannot place feature library first time after viewing simulation results
PR 7173728: Orientation plane is skewed when locking to plane during hole placement
PR 7174023: Measurement line not displayed in this workflow
PR 7174072: Style Organizer shows wrong file and always defaults back to that file if change
PR 7174099: Dimension text doesn't print
PR 7174567: Flat Pattern cmd QB displayed partially after view manipulation cmd is executed
PR 7175074: User not prompted to save on closing after pasting FEA elements
PR 7176003: 3d sketch responds slowly while drawing especially when other geometry
PR 7176505: Using the scroll wheel causes values to go to beginning of range instead of next
PR 7174824: Profile region performance issue
PR 7185374: Tapered external pipe threads fail to apply correctly
PR 7185661: Thread length incorrect when placed using system selection
===Mold Tooling===
PR 7169079: Abort when creating runner bars on one side only
===Insight===
PR 1984313: "Free Text" search problem with option "Search for results in subfolders"
PR 7142238: Insight: Revisions issue with LCA & Revise operations losing revision history
PR 7181475: Error in saving any new file to Insight Server in ST7
===Insight Connect===
PR 1990745: Standalone Solid Edge Viewer doesn't open all parts
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 7167082: Save As action saves psm to an already existing prt and overwrites its dft.
PR 7168085: Can't access RMB menu in new web browser session
PR 7169528: dwg and .pdf files not uploaded to location defined by SESP URL property
PR 7169551: For some folders, objects are not getting populated in delete dialog
PR 7173862: Save As All in Structure Editor generates different sequence numbers
PR 7176714: Workflows get stuck when an object is checked out
PR 7177270: Synchronize command fails with UAC enabled
PR 7177731: Cannot populate Look In field on Search dialog from Add to PCF
PR 7183870: Upgrade from ST6 to ST7, STD parts doc lib seen under wrong site
===Solid Edge Embedded Client===
PR 1992713: Add To Teamcenter Interactive incorrect Item ID when using display names
PR 1992719: SESE not using Naming Rules on Item Id and Item Name correctly
PR 6986382: MRU shows wrong preview when mutliple revisions are in the MRU
PR 7110098: Save As- User gets file load failure using this workflow
PR 7133799: CPD Ctrl-V paste does not keep values if the user double clicks the field first
PR 7157794: SEEC CPD - Save Copy As on an item with a drawing, gives a different part number
PR 7168042: SEEC Diagnostic: "TEAMCENTER DATABASE LIST" is not populated
PR 7168075: SEEC Diagnostics: Info is missing from log if FMS can't start
PR 7168465: MT9_Drawing item type naming rule patterns for ID and revision are ignored
PR 7168981: Unable to perform action if dataset having broken XLS link for this test case
PR 7170830: Insert Part Copy behaves differently in Solid Edge managed vs. unmanaged
PR 7174699: Asian characters in TAL log for English system
PR 7175353: Remove All on the Project ID will not remove the Project ID for model and draft
PR 7176006: The Insert Weldment link is shown as a red question mark
PR 1991572: Problem setting SEEC_ItemTypeList_SE Part and SEEC_ItemTypeList_SE Draft
PR 7169854: Item Name in Solid Edge CPD not synchronizing between Part and Draft file
PR 7182263: Mapped date property is converted to a custom text property via SaveAS
PR 1993092: BOM mismatch with Save As Copy of read-only Precise IPA'ed assembly structure
PR 7176282: Crash observed while repairing broken link
PR 7181609: Preview Image on Cache Assistant dialog is distorted as width is increased
PR 7182797: Save As of draft with Asm does not update Asm dataset name with revision
PR 7189106: Save as fails for this specific Teamcenter Item revision
PR 7118226: Import Template reports Success if FMS not configured correctly
PR 7168059: Open as read-only setting uses stale data
Fred White
Siemens PLM Software
Re: Solid Edge ST7 - Maintenance Pack 1 Announcement
1. Please, document officially how to deploy ST7 MP1 silently. Setup.exe /s does not seem to work now? It is important generally for the updates to be automated /and controlled/.
2. Are you planning to develop or use some better update technology? MSP files, auto update within the program (like Autodesk), etc.?
I hope that as SolidEdge is being improved in some areas like Synchronous Technology, other areas like updating, options deployment (without need of user interaction) for multiple users will be improved as well.
Mesru
What's wrong??
Solid Edge ST10 & AutoCAD 2018.1 user
I believe you try to install the share point maintenance pack instead of the Solid Edge maintenance pack.
The file is in the screenshot.
Why oh why is this prehistoric update system still in use...
Even free software has a "check for update" button which starts the correct update process after one click.
The Solid Edge ST7 maintenance pack file is called:
Solid_Edge_MP1.exe
the file you have downloaded is for the Share Point client.
Indeed, I looked over it. Thanks
Nevertheless, I still don't understand this kind of work...
Built in update system and maintenance uninstall should be implemented for a better user experience.
Is it time for an enhancement request ?
Hi Mesru,
you have to unpack the provided ...MP1.exe file.
(I am using 7zip software to do this).
After unpackicg, there is a bunch of files. I use this script for silent install of MP
It works for ST6, not tested on MP1 for ST7, but I pressume that there will be no changes in MP install package.
Script:
"%folder%MP\MP10\SE64MP10\setup.exe" -s -f2C:\temp\ST6MPXXsilentsetup.log
Hope this helps.
Ota
I had no crashes until MP1.
Already 5 since yesterday.
Am I the only one?
