Re: Solid Edge ST7 - Maintenance Pack 1 Announcement
And again...
Without an error report...
This happens when I try to save my Assembly (Alternate assembly)
This is something that already gives problems for years. When I use alternate assembly SE chrashes a lot.
Solid Edge 2019 & AutoCAD 2019 user
Doesn't work. I need information for ST7, not ST6, that is tested.
Thanks anyway.
Silent install does work for ST7 MP1 as I've done it.
  1. Unzip the downloaded maintenance patch to a folder.
  2. In that folder run "setup.exe /s" from a command prompt.
The maintenance patch will install silently.  Be aware that a log file is written in the folder where setup.exe is ran from so whomever runs it needs write access to this folder.  If distributing to many clients who may run it at the same time, it needs to be copied to their workstation and ran from there to avoid conflicts.
Production: ST10 MP9, Testing: SE 2019
http://Grundey.blogspot.com
Does MP1 work correct?
I can't download it, our network has some bugs again (need to call pest control).
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Dear,
I upgraded but the error occurred, Please help me!
Best Regard,
BuiTu
@BuiTu wrote:
Dear,
Hi there,
If you have'nt already, try this....[after a fresh Windows restart] right click on the ".EXE" file and select "Run As Administrator".
Solid Edge 2019 [MP1] Classic [x3 seats]
Dear Mr. Sean,
I  have done as your guide (Restart -> right click on the "Solid_Edge_MP1.exe") but the error still happens as before
Best Regard,
BuiTu
Have you checked that "MP1" hasn't already applied correctly, regarless of the message you're seeing?
What do you get when looking under "About Solid Edge"??, do you see "Version 107.00.01.05 x64"???
I have checked. I see Version 107.00.00.090 x64
Best Regard,
BuiTu
That's all I've got I'm afraid.
....short of the worst case scenario - uninstall > run SE-CleanUp [on the DVD] > reinstall Solid Edge.
