Solid Edge ST7 - Maintenance Pack 10 Announcement
Siemens Legend Siemens Legend
Siemens Legend
October 5, 2015
Dear Solid Edge Customer:
Solid Edge ST7 Maintenance Pack 10 for Solid Edge is available for download.
The Solid Edge Team
Release Notes:
Maintenance Packs are released for CRITICAL items only. Maintenance Packs are available up to a maximum
of 15 months following the release date of the English version. The release date for Solid Edge ST7 English was
08/08/14, making the Maintenance Pack cutoff date 11/08/15.
Download Location:
ST7 Maintenance Packs can be downloaded from:
There were Solid Edge Embedded Client policy file updates in MP2. It’s vitally important that you install SEEC
Administrator, which delivers the policy files to TC_DATA.
Maintenance Pack Executables (.exe files) patch existing product dlls. Maintenance Pack executables
are all inclusive and can be installed on top of a base release or any released Maintenance Pack.
Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be
uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: for the web interface.
This Maintenance Pack addresses the following PRs:
PR 7467945: Need a method to kill a command from the BeforeCommandRun event
PR 1989085: Setting subassembly as adjustable and assemble it cause that patterned parts be
PR 7383011: femap running in background, locking up my assembly
PR 7478836: Solid Edge Physical Properties not matching results from API
PR 7453978: Hole Feature recompute Fails in certain cases
PR 7475687: Interpart Project with offset giving incorrect result
PR 7376599: Honor hidden explode flow line in drawing views with explode configurations
PR 7445736: undesirable segments remained after converting a view to 2d
PR 7454662: a custom property named "Positionsnummer" does not work anymore since ST6
PR 7460592: If there is not 3D model, the dimensions of the Dft file move
PR 7467096: Problem with dimension placement
PR 7476472: Dimensions disappear when they open the Dft file in "Inactive"
PR 7479182: When there is not 3D model/ open Inactive, Feature Control Frame becomes longer
PR 7481474: Parts List item numbers are N/A on file open when file is opened inactive
PR 7488330: Linear dimension moves if draft file opened without 3D data /Inactivate dwg view
PR 7494666: When there is not 3D model, the dimension moves
PR 8508749: Dimension moves far away when used attach dimension
PR 8510182: Linear dimension moves if draft file opened without 3D data /Inactivate dwg view
PR 7400253: Fixed sectioning failures for some models
PR 7495622: Parts List not displaying frame items
===Part/Profile/Sheet Metal===
PR 7448157: sheet metal part can no longer be edited
PR 7510126: Not possible to connect to multiple elements
PR 7450577: Sporadic error message when creating a copy of a dft file with Revision Manager
===Insight Connect===
PR 7481541: API Regression since ST 7 MP7 concerning Revman
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 7462078: Custom Properties can't be added to the BOM Report
===Solid Edge Embedded Client===
PR 1996834: Document Name formula problem within API, window will not update
PR 7429671: Initial value required attribute not available in ATT Interactive
PR 7428885: Create a new part returns a TC error
PR 7465071: Dxfout - Save As Flat: Etch Text alignment (Centered) exported as left justified
Fred White
Siemens PLM Software
