Solid Edge ST7 - Maintenance Pack 3 Announcement
Siemens Legend Siemens Legend
Siemens Legend
December 15, 2014
Dear Solid Edge Customer:
Solid Edge ST7 Maintenance Pack 3 for Solid Edge is available for download.
Sincerely,
The Solid Edge Team
Release Notes:
Maintenance Packs are released for CRITICAL items only. Maintenance Packs are available up to a maximum
of 15 months following the release date of the English version. The release date for Solid Edge ST7 English was
08/08/14, making the Maintenance Pack cutoff date 11/08/15.
Download Location:
ST7 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST7/Maintenance_Packs/
Installation:
There were Solid Edge Embedded Client policy file updates in MP2. It’s vitally important that you install SEEC
Administrator, which delivers the policy files to TC_DATA.
Maintenance Pack Executables (.exe files) patch existing product dlls. Maintenance Pack executables
are all inclusive and can be installed on top of a base release or any released Maintenance Pack.
Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be
uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
This Maintenance Pack addresses the following PRs:
===API===
PR 1127638: SheetSetup::GetDefaultDrawingViewScale method
PR 7231588: GetMappedPropertiesForGivenFile does not read properties from Part or Revision
===Assembly===
PR 7120417: unloading hidden parts leaving some subassemblies in a bad state
PR 7165893: Frame color changing when a 3D Sketch command is started
PR 7222695: dialog displaying when part is edited
PR 8250596: motor simulation regression
===Draft===
PR 1986693: Item count balloons that don't have a parts list are not updating
PR 2250765: Dimensions move when I open draft file in ST6
PR 7218956: Solid Edge crashes after using extend command
PR 7223291: Changing the fill style is not recognized when placing a section
===Part/Profile/Sheet Metal===
PR 7216664: Crashing when editing a protrusion in Simplify mode
PR 7226815: Save As translated -SE file extension is added to file name
PR 1128844: NX9 part can't be loaded and saved to ST6
PR 7223207: Tapered Thread input angle is ignored and defaults to 2.5° in Ordered
PR 7225894: Physical properties hidden after material is applied to model
PR 7189198: Simulation/deflection, color reflection on the part does not update correctly
PR 7232099: Cannot set material in Simulation Express.
PR 7240989 : Problem with BlueSurf with tangent end conditions creates dependency loop
===Insight===
PR 1992524: Too long time when saving a new draft file in Insight - Actions on asm and par
PR 1995321: Insight File open extremely slow - CPU intensive time during Deep Tree Generation
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 1996701: Part Title not mapped to Item Title
PR 7215405: Catch SP event mechanism failure needs to be back ported into ST7 MP
PR 8250103: Duplicate local check-out
===Solid Edge Embedded Client===
PR 1127691: ST6 removes TC-Absolute-Occurrence Information during upload/check-in
PR 1129564: SEEC Save As incorrectly displays Item Name in CPD when linked Item Rev exists
PR 7130564: SEEC Admin changes the values for item number synchronization when updated
PR 7182243: Replace one rev with another errors
PR 7183486: Save As of FOP member creates a SE Interpart Family link back to FOP master
PR 7225135: Revise creates wrong dataset name when specific custom property exists
PR 8252609: Save As with Structure Editor saves a wrong item name
Fred White
Siemens PLM Software
Re: Solid Edge ST7 - Maintenance Pack 3 Announcement
SE4SharePoint server appears to be missing the file...
http://Grundey.blogspot.com
