Solid Edge ST7 - Maintenance Pack 6 Announcement
Siemens Legend Siemens Legend
Siemens Legend
April 7, 2015
Dear Solid Edge Customer:
Solid Edge ST7 Maintenance Pack 6 for Solid Edge is available for download.
Sincerely,
The Solid Edge Team
Release Notes:
Maintenance Packs are released for CRITICAL items only. Maintenance Packs are available up to a maximum
of 15 months following the release date of the English version. The release date for Solid Edge ST7 English was
08/08/14, making the Maintenance Pack cutoff date 11/08/15.
Download Location:
ST7 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST7/Maintenance_Packs/
Installation:
There were Solid Edge Embedded Client policy file updates in MP2. It’s vitally important that you install SEEC
Administrator, which delivers the policy files to TC_DATA.
Maintenance Pack Executables (.exe files) patch existing product dlls. Maintenance Pack executables
are all inclusive and can be installed on top of a base release or any released Maintenance Pack.
Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be
uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
This Maintenance Pack addresses the following PRs:
===API===
PR 7320225: Crash when using TextProfilesPtr GetCount on simple Sketch Text feature
PR 7325992: SetPropertiesInfo API does not allow the dataset name column to be cleared
===Assembly===
PR 7246804: Unable to access peer variables while in a sketch
PR 7250005: User was not able to edit frame
PR 7277410: Assembly crashes when opening
PR 7306907: Assembly aborts when opened
PR 7323166: Can’t create a second relationship with the assemble command
PR 8252662: Report in Assembly destroys User-Defined Mass of Sub-Assemblies
PR 7286889: Physical properties calculation saves material to part
PR 7295498: Parts jump on update all
PR 7319406: Assembly relationships fail after an assembly feature creation
PR 7336384: Solid Edge crashes when trying to place a T fitting
===Draft===
PR 7288091: DV become out of date, once an assembly has been opened
PR 7297427: Save as DXF regression from ST6
PR 7300422: Callout moves when open ST4 dft in ST7
PR 7304841: Repeated error message on mouse move
PR 7310012: Parts list update removes all rows for simplified sub-Asm
PR 7321142: same file name overwrite problem
PR 7322543: Draft file cannot be open and SE crash
PR 7251550: Automatic Coordinate Dimensioning very slow
PR 7324778: Drawing view of assembly doesn't default to no configuration
PR 8251882: Drawing View Properties / Style page shows the wrong style
PR 7315292: Slow Movement of Coordinate Dimensions
PR 7341723: Wrong dimension on broken revolved section view
===Part/Profile/Sheet Metal===
PR 1996595: Problem with shortcut key M in 3D IntelliSketch
PR 7203030: Cannot multi-select tangency handles while IPA'd into a part
PR 7321211: Combo box for sheet metal gage is too small in ST7 compared to ST6, regression.
PR 7308628: style if placed from Feature Library
PR 7335849: Crash while closing sketch with an active smart dimension/measure command
PR 7320068: Radial_Diameter_* is not properly adjusted if the Hole_*_Diameter is modified
PR 8250544: Insert sketch does not create a sketch
===Translators===
PR 7212861: Unable to open this SW file in Solid Edge.
PR 7303255: ST7 Crashes with SEPvTrn.ini file modified
PR 7306972: BOM View web part is crashing when selected
PR 7178850: Opening a SW assembly only translates the first part
PR 7254353: If unit is other than meter then JT generates model with white
PR 7296388: SolidWorks Data migration stops intermittingly
PR 7217433: Assembly constraints become corrupt when using MultiCAD driven references
===Insight Connect===
PR 7250363: Where used (search for asm) in revision manager very slow
PR 8253660: Rename of part and draft files breaks link from Drawing View to part file
PR 7206624: Labels missing for some commands when localized
PR 7334004: Cannot select Revision Rules when using UNC-defined Network Location
===Insight===
PR 8261109: Free Text Search and Where Use doesn't work
PR 7332037: Insert a new assembly by drag and drop “Cannot download a document”
PR 7307476: Impossible to add document number
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 1128335: SP Package File creation deletes Cache Content
PR 1970312: Pathfinder not displaying custom workflow status icons
PR 7226430: Support Multiple Site Collections Simultaneously in ST7 MP
PR 7239757: Files are not being uploaded to SESP
PR 8258870: Data Prep Tool Analyze reports File contains property without valid name
PR 1936459: SEEC Item numbers synchronization rolled back after AddToTeamcenter
PR 6958514: SESE revise is using the default NR and not the one used in the file
PR 7231415: SEEC & TC FCC error if working with weldment assemblies
PR 7294822: Revision Rules for Related Documents
PR 7159300: File Folders added to SE for SP are always lower case letters - hard to read
PR 7288590: Performance problem when revising simple part and linked draft
PR 7332162: Drag and drop unmanaged part in assembly, incorrect symbol shown in path finder
PR 8259356: Workflow target is not valid for action Assign Status
PR 7312476: During upload of multiple MANAGED docs got errors that deleted the cache
PR 7312433: Search dialog takes 5-7 seconds just to display
===Solid Edge Embedded Client===
PR 7332854: does not assign project info, correctly during a revise operation
PR 7334006: Local BOM Precision Override
PR 8263114: AddToTeamcenter interactive doesn't honor the preference SEEC_property_item_name
Fred White
Siemens PLM Software
