Solid Edge ST7 - Maintenance Pack 7 Announcement
Siemens Legend Siemens Legend
Siemens Legend
May 18, 2015
Dear Solid Edge Customer:
Solid Edge ST7 Maintenance Pack 7 for Solid Edge is available for download.
Sincerely,
The Solid Edge Team
Release Notes:
Maintenance Packs are released for CRITICAL items only. Maintenance Packs are available up to a maximum
of 15 months following the release date of the English version. The release date for Solid Edge ST7 English was
08/08/14, making the Maintenance Pack cutoff date 11/08/15.
Download Location:
ST7 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST7/Maintenance_Packs/
Installation:
There were Solid Edge Embedded Client policy file updates in MP2. It’s vitally important that you install SEEC
Administrator, which delivers the policy files to TC_DATA.
Maintenance Pack Executables (.exe files) patch existing product dlls. Maintenance Pack executables
are all inclusive and can be installed on top of a base release or any released Maintenance Pack.
Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be
uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
This Maintenance Pack addresses the following PRs:
===API===
PR 1128909: SegmentPointRelation3d.GetElement method fails on connection to other assembly
PR 7326618: API Interpart references are broken
===Assembly===
PR 1997310: thread feature fails in standard part screws
PR 7238389: Changes in Variable Table has no effect on other depending variable
PR 7288288: Handle points of frames moved after Update all links done
PR 7329238: Files opening with Read Only status when they are available
PR 7340152: Relation fails in assembly
PR 7340513: Crash when editing a multiple profile assembly feature
PR 7347154: not getting immediate feedback indicating that relationships have failed when IPA
PR 7351598: missing assembly features when opening from Draft
PR 7360551: Subassemblies being empty when any instances are not tagged "display in higher level"
PR 7339408: Cannot download the document message in open file dialog
PR 7345683: File units change for legacy files in ST7
PR 7286029: The values are overridden and updated in the SE options
PR 7343765: Missing properties on a Family of Assemblies - Please repair file
PR 8266361: System error encountered during evaluate while editing 3D sketch
PR 7283939: decimal places in assembly physical properties mass moment of inertia is locked
PR 7329334: Alternate Assembly previews not being correct
PR 7362568: not being able to edit a failed connect relationship
PR 7249140: Parts disappear from the display
===Draft===
PR 7328318: Property Text "Last printed date" will not be updated - wrong date on printout
PR 7234234: vertex edges were incorrectly suppressed in a section view of an assembly
PR 7235932: 3d connection device leaves fence select artifact
PR 7335228: Opening a DFT file crashes Solid Edge
PR 7337320: Block in Drawing View will not be exported
PR 7342543: Incorrect section view display
PR 7353124: Wrong dimensions in a Draft, when broken out section view exists
PR 8253818: Material Table > customer properties cannot be retrieved e.g. in Draft
PR 7304635: Shaded draft view colors inconsistent
PR 7360547: Repeatable ST7 crash in Draw In View
===Part/Profile/Sheet Metal===
PR 1996278: Unable to access edgebar features via API
PR 7295029: Deleting a hole profile locks Solid Edge if relationship colors are turned on
PR 7325679: Creating a 3D sketch, Solid Edge will crash
PR 7340095: SE crashes due to NULL pointer access
PR 7340385: Solid Edge crashes if a feature has the same name as the solid body
PR 7356608: Dimension Type Feature Callout slows down the graphics performance
PR 7357175: Hole feature changes geometry after editing the hole, that came via hole recognition
PR 7175521: Part dimensions change after doing a save-as
PR 7298290: Unable to repair web network
PR 7309165: Profile side changes direction when editing variables
===Translators===
PR 1991712: JT with long PMI causes crash
PR 7234372: Problems to import SAT files to ST7MP2, regression against ST6
PR 7294318: Document name Formula will not be taken in 3d PDF
PR 7351253: Solid Edge Viewer keeps psm files within an assembly opened for several minutes
PR 7355757: Save as jt not possible - Insufficient error message
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 1997720: Cannot sync exposed SE dimension variables to SESP numeric columns
PR 7172511: Pathfinder do not get update with the assigned numbers for drag n drop assembly
PR 7221411: BrokenLinkLog.xml does not include Alternates when running from cmd line
PR 7322191: Sync property values across part structure
PR 7340397: Where Used on sub-part, Revision.Title values not populated
PR 8265581: Content Browser shows only Favorite and Site Name - expand not available
PR 6974655: Numbering used to generate SE Standard Parts is incorrect
PR 7332477: Shen the browse folder is accessed from WC or EC there is bad performance
PR 7346513: Doesn't handle the Title (German Title) column as required
PR 7346893: Workflow Action "Update Drawings" creates unnecessary tasks
===Solid Edge Embedded Client===
PR 7283519: ASM occurrence property, Item Number are not being maintained from the TC BOM
PR 1993522: Revision field is blank in CPD when naming rule used
PR 7186212: Doing SaveAs of a NX driven reference assembly gives a Tc rules error
PR 7244837: Mandatory attribute in Teamcenter won't appear in "Add to Teamcenter" in SE
PR 7324478: SaveAs copies ItemRevision name from source to new object in 10.1.3
PR 7355261: Solid Edge Structure Editor not displaying the correct items
PR 7355760: Revise generates Partial Error
PR 7357577: create draft from model results in empty CPD
PR 7370456: Save as from managed draft does not properly do link fix up to new assembly
PR 7287253: Takes a very long time to open assembly files in SE Structure Editor
Fred White
Siemens PLM Software
Re: Solid Edge ST7 - Maintenance Pack 7 Announcement
Honored Contributor
Honored Contributor
Very good. About half of the sheet metal stuff applies directly to me and explains many crashes and slow downs I have experienced.
