Solid Edge ST7 - Maintenance Pack 9 Announcement
Siemens Legend Siemens Legend
Siemens Legend
September 4, 2015
Dear Solid Edge Customer:
Solid Edge ST7 Maintenance Pack 9 for Solid Edge is available for download.
The Solid Edge Team
Release Notes:
Maintenance Packs are released for CRITICAL items only. Maintenance Packs are available up to a maximum
of 15 months following the release date of the English version. The release date for Solid Edge ST7 English was
08/08/14, making the Maintenance Pack cutoff date 11/08/15.
Download Location:
ST7 Maintenance Packs can be downloaded from:
There were Solid Edge Embedded Client policy file updates in MP2. It’s vitally important that you install SEEC
Administrator, which delivers the policy files to TC_DATA.
Maintenance Pack Executables (.exe files) patch existing product dlls. Maintenance Pack executables
are all inclusive and can be installed on top of a base release or any released Maintenance Pack.
Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be
uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: for the web interface.
This Maintenance Pack addresses the following PRs:
PR 7418372: CommandInfo::Icon returns HICON of image list instead of a command icon bitmap
PR 7415571: API: ModelNode::GetCutLength returns 0
PR 7437107: The API 'ThreadDataByDescription' does not work in ST7
PR 7457728: constraint.GetGeometries API does not return the correct geometry
PR 7405944: not exiting the command when a subassembly becomes fully defined during placement
PR 7410611: Added Display Dimension control to the Occurrence API
PR 8264755: "Save Simplified Assembly As" failing
PR 1928569: Wrong Amount in "Atomic Parts List" (Reports and Draft)
PR 7413477: Expand All causing part files to load
PR 7423057: user is unable to copy sketch into opened Subassembly
PR 7432598: Updating all Open documents on each Peer Variable Table record update
PR 7439634: Item number blank and read only in occurrence properties in FOA files
PR 7446113: part status not correct when adding tangential relations
PR 7457275: Interference checking on construction surfaces in ST7
PR 7459332: not being able to drag a component in some scenarios when going between a selected edge and a triad axis
PR 7462671: inactive simplified subassemblies not being included in physical properties calculations.
PR 8506060: Break links does not exist on the edit links dialog in ST7
PR 7463722: "Display in Higher Level" setting will not affect physical properties calculations
PR 7470955: PMI Section view does not cut a fillet weld
PR 7384379: Unusual semi-circles appear in some dual dimensions
PR 7415256: Grid disappears when switching sheets
PR 7415586: Parts List changed unacceptable after update views
PR 7363506: Loop test does not include spreadsheet
PR 7376599: Honor hidden explode flow line in drawing views with explode configurations
PR 7405632: Tolerance becomes abnormal when I change a text scale
PR 7407307: Blocks on background sheets not exported to DXF
PR 7432084: Solid Edge crashed while reading entities
PR 7436337: Tangent command is in a bad state after pressing SHIFT and middle mouse button
PR 7440042: Drawing View Properties / Style page shows the wrong style
PR 8505679: Direction of displacement is reversed in the saved image
===Part/Profile/Sheet Metal===
PR 7421230: Crash when inserting feature library
PR 7392093: Driving dimensions do not accept decimal values
PR 7434569: KeyShot import issue
PR 7247507: Problem of changing geometry in Sheet Metal Assembly
PR 7271837: Deselected region reselected when green checkmark clicked
PR 7437087: Smart Dimension locks 2 files up - Please repair in ST7
PR 7441752: Transfer from styles via material.mtl doesn't work correctly
PR 7444567: Unusual semi-circles appear in some dual dimensions
PR 7448157: Sheet metal part can no longer be edited
PR 7398888: Difference in assembly contents and relationship when opened with different user
PR 2215861: SaveCopyAs changes Author value in Summary Property to Windows User Name
PR 7143583: Revise via SE is changing the author property
PR 7361387: Unit Tolerance for Insight Managed files doesn't work - Dot / Comma problem
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 7387776: Crash seen on sending part to RB which saved under a folder that has "," in name
PR 7408925: SESP Client performance slow on Address -> Select Folder dialogue
PR 7431109: Select Folder dialog for New Document is incomplete if Windows Display is 150%
PR 8274706: SESP workflow issues: SESP people picker web part takes lot of time to load
===Solid Edge Embedded Client===
PR 6971928: Save As- PDF for draft does not exist under new item revision
PR 7412957: Multiple scenarios where SESE will either crash or freeze
PR 7429671: SEEC: Initial value required attribute not available in ATT Interactive
PR 7458795: SEEC - revise all of a complex structure assembly does not finish
PR 8263114: AddToTeamcenter interactive doesn't honor the preference SEEC_property_item_name
PR 7426671: Solid Works files won't open in Solid Edge
PR 7428388: On some parts of the assembly SE in sync mode cannot recognize holes
PR 7428887: Export to 3D pdf, KeyShot, SEV creates several instances of the same part copy
Fred White
Siemens PLM Software
