10-07-2014
11:17 AM
- last edited
a week ago
by
AmyReyes
I downloaded Solid Edge ST7 Student Edition and I have a Windows 7 Home Premium 32 bit, processor Intel Core2 Duo. When I try to start the setup, an error message appears, saying that the processor doesn't support the installation package. What can I do?
Is it possible to download a previous version of the software that can be supported by the processor?
Solved! Go to Solution.
10-07-2014 03:59 PM - edited 10-07-2014 04:02 PM
Hi there,
Good & Bad news....
Good: As of the ST7 release, Solid Edge is only a 64bit application.....so requires 64bit Windows 7 [minimum]. To take advantage of much more memory addressing.
Bad: You will have to stay on ST6, to be able to run it on a 32bit version of Windows.
Solid Edge ST10 [MP6] Classic [x2 seats]
10-07-2014 05:38 PM
10-07-2014 05:47 PM
Hi there,
Try the link below.....the ST7 license code you have already recieved should still work with ST6. My daughters laptop is still running 32bit Windows with Solid Edge ST6 Student Edition just fine....not to say she isn't nagging for new 64bit Win8.1 laptop.
http://www.plm.automation.siemens.com/app/dl/SolidEdgeV106ENGLISH_32Bit.exe
Recommend saving the download to a DVD or flash drive for safe keeping....in case you need to reinstall at a later date.
10-08-2014 05:51 PM
10-08-2014 06:22 PM
Dang it...
Just a thought...have you tried Copy/Paste the text string from the email, into that field directly? Just in case there is some weird formatting difference in a manually typed iteration.
10-09-2014 02:53 AM
10-09-2014 09:07 AM
I have the same problem, but with ST5 version. Academic code sent to my e-mail doesn't work. I'm slowly starting to think, that it's end of my adventure with Solid Edge. It's very bad, because I spent a lot of time learning how to operate it and emidiately I don't have an opportunity to continue my work :-( Learning another free CAD software to be able to make projects to school doesn't smile to me.
10-10-2014 11:30 AM
Each academic key is also tied to a version. So unlike a commercial license, these are not downward compatible. You need an ST6 key for ST6 install. The registration though I believe only generates the current version. So I will see what I can find out regarding registering ST6 once ST7 posts.
10-10-2014 12:36 PM
Ok, I'm waiting for new informations. Thank you!
