Solid Edge ST8 Edit Box not available
I am using Solid Edge ST8 Trial version. When I dimesion a sketch the Edit Box never appears so I cannot correct the dimensions to the ones I need and want. Does anyone have an idea of how to turn on the Edit Box?
I have looked through everything I can find in Solid Edge Help and there is a lot of information about using the Edit Box but nothing about how to turn it on or activate it.
Thank you in advance for any help you can provide.
Re: Solid Edge ST8 Edit Box not available
I solved this problem myself. From the file SEWebInstall I reinstalled Solid Edge overwriting the previous install. This repaired the installation and the Edit Box appears now.
