Solid Edge ST8 License
I recently registered for the student edition of Solid Edge 8. I downloaded and installed Solid Edge. However when I went to launch the program a pop-up occurred and said that Ii would need a licence for first time use. In my welcome email, I was told that the student edition has an embedded license which will activate during installation. I thought that maybe I should click "I have an activation code" and then input the SE CID in the upper right hand corner of the window. When I tried this everything seemed to work correctly until I received an error message that said "Your order is currently being processed please try again later." I have tried uninstalling and reinstalling I have even re downloaded and then reinstalling it with no luck.
Any help would be greatly appreciated.
Re: Solid Edge ST8 License
Siemens Legend Siemens Legend
Siemens Legend
Hi @RWB
Sorry to hear you are having licensing problems.
Please forward your registration email to me and also attach the SELicense.dat file in your Solid Edge ST8\preferences folder.
Melanie
melanie.baeske@siemens.com
