Re: Solid Edge ST8 Microsoft Installer (MSI) Maintenance Pack 1
Master
Master
Cannot install the MP01 of ST8Smiley Frustrated
See screenshot:
Until now, I am not happy with ST8. What a lot of problems with StdParts and with MP1. Cannot believe this
Why does it say Solid Edge Version 107.00  (Solid Edge ST7) ? Do you have ST7 & ST8 on the same computer?
Theodore
Kind regards,
Theodore Turner
Solid Edge 2019 MP6
Teamcenter 11.3
Siemens Legend Siemens Legend
Siemens Legend
Hi Remko VanDijk,
I have opened and IR (7496099) for you requesting the local Partner/GTAC team follow-up on your install problem.
Fred White
Siemens PLM Software
Does this mean solid edge could be set to auto update?
That would be a novel concept as our IT department is currently 5 MP's behind.
Greg Patchel
Win 7 SP4 64 Bit
HP Z400 ST7 MP4
16GB RAM 3.2GHz
NVIDIA Quadro 2000
There are two kinds of people, those that can extrapolate from incomplete data...
Fred,
I tried to install SE ST8 MP1 on ST8 with Mold Tooling installed, but it only updates SE. SEMT remains the same version, although the ReadMe says, there is a fix in SEMT.
I know, there is a fix in SEMT, because I have send it to Siemens, but as there is no separate setup file, I was expecting the fix being included in the SE Update.
How can I update Solid Edge Mold Tooling ST8 (without using my own files, of course ;-)?
Siemens Legend
@MartinBernhard wrote:
Fred,
Hi Martin,
I am very sorry, but it appears that I overlooked Mold_Tooling_MSI_MP1.exe when I was posting the other files. I have posted MT MP1 and it should sync with all servers around the top of the hour.
Fred White
